VPN design question
Jan 11th, 2010
We have ASA 5500 as a VPN server, then we have several differnt clients:
- remote home users (ompanie's employees)  - we decided to use AnnyConect SSL VPN client
- partners  - clientless access to web-applications
- several offcies that aere "mobile" - here is my question "what kind of clinet is to use?"
"mobile" office is office that our company isntalls in differnet expositions. Each such office has router 8xx that should provide remote access for several PC and printer. Printer can not create VPN session, this is why we can not use SSL. What is the best VPN solution for such "mobile" office?
ngorenko Tue, 01/12/2010 - 01:47
Hi Conor,
Thank you for answer. I looked: both samples described site-to-site VPN with fix ip address as a tunnel end point. Is it exsit some possibility to make configuration for non-fix ip address at the remote site router?
conmurph Tue, 01/12/2010 - 13:46
I don't have much knowledge about VPN's so hopefully one of the experts can add to this. From the following links it looks as though you can configure the remote side to have a dynamic IP while keeping the main site as a static IP.
