NAC version upgrade from 4.5.x to 4.7.1-in different geographical location
Jan 11th, 2010
I have more than fifteen CAS’s in different geographical location (state) and controlled by CAM HA that is located in another location (state). I’m currently running NAC version 4.5 and planning to upgrade to 4.7.1. due to Windows 7 compatibility problem. My question is that, what is the easiest way to upgrade to 4.7.1  without visiting each location to upgrade CAS’s? Is there away to push the new version from the CAM? Visiting each location is not that convenient. Please let me know.
Faisal Sehbai Thu, 01/14/2010 - 07:39
  • Gold, 750 points or more
Dereje,
Unfortunately for upgrading to this version you need the CD in the box and to reboot from that CD. Reason is that we're changing the underlying OS from Fedora Core to CentOS and that requires a complete re-install of a lot of RPMs which isn't possible without booting from the CD.
HTH,
Faisal
