NEXUS 5010 password
Answered Question
Jan 11th, 2010
how do you recovery a lost password on a nexus 5010.  or is there a default password for the nexus
Correct Answer by johgill about 7 years 5 months ago
Jerry,
It can be tricky.  It's best to make sure you do this while at 9600 baud on your console.  Try using "ctrl + b" a few times after seeing the text "POST is completed"
John Gill
Overall Rating: 5 (1 ratings)
Jon Marshall Mon, 01/11/2010 - 09:25
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Nexus password recovery
Jon
jerrymurray4 Mon, 01/11/2010 - 10:17
Jon,
I have tried the steps you metioned in the document.  it seems the break command is not working.
I have tried the Ctrl ] and the Cntrl B, niether seem to be getting me to the switch (boot) > prompt
Jerry
jerrymurray4 Mon, 01/11/2010 - 10:19
John,
I have tried the steps you metioned in the link.  it seems the break command is not working.
I have tried the Ctrl ] and the Ctrl B, niether seem to be getting me to the switch (boot) > prompt
Jerry
Correct Answer
johgill Mon, 01/11/2010 - 11:05
  • Bronze, 100 points or more
Jerry,
John Gill
I have read the Nexus 5000 and I am also having great difficulty getting into the password recovery.  Can someone clarify, in the password recovery document when ctrl-b or ctrl-] is referenced, the Nexus is looking for the BREAK signal.
Terminal emulators
teraterm = Alt-b
putty = ctrl-break
securecrt = ctrl-break.
This is the same BREAK signal that allows password recovery on Cisco Routers?
I have been attempting the power cycle method but do not seem to be able to inter the break signal at the correct time (I am using securecrt), Here is where I am trying:
Booting kickstart image: bootflash:/n5000-uk9-kickstart.4.1.3.N2.1a.bin....
.........................................................................Image
verification OK
Starting kernel...
Usage: init 0123456SsQqAaBbCcUu
INIT: version 2.85 booting
Starting Nexus5010 POST...
  Executing Mod 1 1 SEEPROM Test......done
  Executing Mod 1 1 GigE Port Test.......done
  Executing Mod 1 1 Inband GigE Test.....done
  Executing Mod 1 1 NVRAM Test....done
  Executing Mod 1 1 PCIE Test..............................done
  Mod 1 1 Post Completed Successfully
POST is completed
Creating /callhome..
Mounting /callhome..
Creating /callhome done.
Callhome spool file system init done.
Checking all filesystems..... done.
ctrl-break
Loading system software
Jim Crider
johgill Mon, 01/11/2010 - 09:35
Jerry,
If you do not see the intitial config dialog, you will need to perform recovery.
The steps are outlined on this page:
http://www.cisco.com/en/US/docs/switches/datacenter/sw/password_recovery/nx_os_pw.html
Basically, you will need to be on the console and "break" into kickstar, then issue a new admin-password, and then continue booting.
Let us know if that document needs some clarification.
John Gill
jerrymurray4 Mon, 01/11/2010 - 11:22
thanks John  I didn't think it would have been that difficult.  it took several tries,  thanks for your help
johgill Mon, 01/11/2010 - 13:54
I'm glad you got it!
crash0verride Tue, 01/15/2013 - 07:53
Hi All,
I have the same issue.
I work on OS X Mountain Lion with USB-2-serial and iterm.
I have tried with ctrl+shift+b or ctrl+shift+alt+] but nothing to do, switch complete boot and prompt login.
Any idea on which short cut could I use on mac to access recovery mode?
erazvi Mon, 11/04/2013 - 10:48
  • Cisco Employee,
On OS X Mountain Lion. I gave up too. Was able to do it via VMware Fusion. If you don't have vmware fusion just find a windows laptop or try virtualbox with windows.
KARAN CHANDRAWANSHI Sun, 02/16/2014 - 09:36
  • Cisco Employee,
Hey guys,
Use Ctrl+C option. This is the break key for Nexus 5010 switch
I faced the same issue.
I reboot the switch and than I gave Ctrl+C key for break and switch comes in switch mode.
I hope this will resolve your issue
