AnyConnect Radius Timeout
Jan 11th, 2010
I have an ASA 8.2.1 that I am managing with the ASDM 6.2.1 software.  I am trying to get a radius connection to work.  The problem is I need to increase the timeout value on the radius connection to 30 seconds or greater.  I currently have this working with the web interface but when I try to connect using your Anyconnect VPN client  2.4.1012, using the same profiles that the web interface uses, the radius connection times out before the authentication event can finish.  Is there a separate place  to configure this or is this a hard coded value.  I would appreciate any assistance you can give me on this matter.  Please let me know if you need any further information to help answer this question.
