01-11-2010 07:46 AM - edited 03-15-2019 09:02 PM
When I try to use the Join softkey to Join two participants together, I receive a "Cannot Complete Conference" error. However, conferencing itself seems to be working fine (taken from a 3 person test conference):
KC_VG_1#sho sccp conn
sess_id conn_id stype mode codec sport rport ripaddr
3221815305 131096 conf sendrecv g711u 16788 2000 10.100.100.253
3221815305 131095 conf sendrecv g711u 16546 2000 10.100.100.253
3221815305 131094 conf sendrecv g711u 16770 2000 10.100.100.253
Total number of active session(s) 1, and connection(s) 3
KC_VG_1#sho dsp dsp all
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 24.3.2 UP N/A FREE xcode 3 - - -
0 3 24.3.2 UP 1 USED conf 2 0x24F 4343 4391
0 3 24.3.2 UP 1 USED conf 2 0x251 4343 0
0 3 24.3.2 UP 1 USED conf 2 0x253 4343 4376
0 3 24.3.2 UP N/A FREE conf 2 - - -
0 5 24.3.2 UP N/A FREE mtp 1 - - -
0 5 24.3.2 UP N/A FREE xcode 3 - - -
Total number of DSPFARM DSP channel(s) 20
I've tried changing from hardware to software conferencing and tried fiddeling with a few other things to no avail.
The user guide doesn't even document Join for CME. I see the feature documented in the admin guides, however, so I assume it should be available for use. I tried using Join with one call on hold and one call active and I tried using Join with two calls on hold. Both tests give the same result.
Thanks in advance for your assistance.
Solved! Go to Solution.
01-11-2010 11:44 AM
You need to add a SELECT key in the
ephone template for softkeys hold.Then when you have the 2 calls on hold press the select key for both lines, you will see a check box.
after both are selected then press join.
01-11-2010 08:24 AM
Exactly how are you trying to use the join softkey???
What are you doing/pressing on the phone??
•Join—Joins an established call to a conference. You must first press Select to choose each connected call that you want to join in a conference, then press Join to join the selected calls to the conference.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1011236
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
01-11-2010 09:05 AM
From my phone (Phone A), I call Phone B. I place that call on hold. I then place a new call to Phone C. I then try to join Phone B into the call.
So, I have a single line key on my phone (octo-line) with an active call and an on-hold call. At this point, I have an active Join key. If I arrow up to the on-hold call, then press Join, I still get the conference error (is this what it means by pressing Select?).
I ran this scenario in IP Communicator so I could get a screenshot.
01-11-2010 10:39 AM
Have you tried with a dual-line DN ?
01-11-2010 11:22 AM
Just tested with dual-line DN as the originating caller (the one trying to use join). Still get the exact same thing.
01-11-2010 11:44 AM
01-11-2010 11:53 AM
Thank you. For some reason, I totally didn't get that from the documentation.
If only features would work the way I think they should rather than the way Cisco thinks they should ;-)
