Moving Callmanager Subscriber
Answered Question
Jan 11th, 2010
In a month or two I am planning to move the Subscriber to another location.  What specifically will have to changed on this system in order to move it over without issues?
Correct Answer by Adrian Saavedra about 6 years 10 months ago
Overall Rating: 5 (1 ratings)
Jaime Valencia Mon, 01/11/2010 - 10:36
Depends, if it's going to be over WAN read the SRND deployment options chapter for specs on BW required.
If to another building but same LAN and if you're just going to move the server, unplug and plug without changing any config on server. That's it
If you're going to change IPs/hostname then modify the CUCM group config and related items (urls, services if configured, etc)
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
rbill1967 Mon, 01/11/2010 - 10:42
It is within the same network, but it is changing IP's.  Will it involve changing some information on the main publisher?
Can you send me the specific link on instructions?
rbill1967 Fri, 02/26/2010 - 08:59
Sorry I did not respond sooner, version 5 (linux) box for Callmanager.  So using the windows version option is not an op
tion.  If I move the subscriber, I am sure I will have to change the IP.  I just want to be sure I have specific instructions on changing it correctly.
Tommer Catlin Tue, 03/02/2010 - 08:55
id recommend simply re-installing it.  Changing IPs sometimes does not go as planned and you spend more time trying to get the dbreplication fixed. (waiting, waiting, and waiting)  Where as a re-install of the subscriber is going to work within 2 hours.
Adrian Saavedra Tue, 03/02/2010 - 09:46
Yes, there will be a lot of trouble fixing DB replication if the procedure is not performed correctly. From my experience, changing the ip address following carefully the instructions of the documentation will not cause issues.
-- Adrián.
