CUC 7.x - No Ringback When Releasing to Switch...
Answered Question
Here is my scenario:
  • The customer would like the Front desk phone to ring for 20 seconds
    • If no answer between the hours of 0800 and 1700 the call should roll to a hunt group for all engineers
      • If no answer there it will forward to the answering service
    • If no answer between the hours of 1700 and 0800 the call should be forwarded to the answering service
The front desk phone is configured to forward to voicemail if there is no answer in 20 seconds.
Once the call hits voicemail it is transferred to a "Engineers" call handler.
The call handler is on a schedule and configured as described above.
Here is the issue:
When the call goes to voicemail and CUC is supposed to release it to the switch all the person on the phone hears is dead air yet the hunt group is ringing.
I know that when you get dead air such as this it usually means that CUC is not releasing the call to the switch properly but I cannot seem to nail it down.
Any assistance would be greatly appreciated!
Thanks!
Dan
Correct Answer by Tommer Catlin about 7 years 2 months ago
Im pretty sure you have an issue at the gateway/CUCM with ringback.    Also, it would on hurt to upgrade your CUCM and CUC when you get a chance.  There are a couple reports of bugs with SIP and transfers.
here is one:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCso04169&from=summary
If there is one, there are typically others
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCta92144&from=summary
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsm31029&from=summary
You can run a quick test and use an internal IP phone to call CUC Call Handler.  (Create a CTI, forward to unity,)  Hit the default opening greeting, enter in a mailbox to transfer to, Unity should do a transfer back out to CUCM and you will hear ring.
I suspected the call was coming from external.  There have been issues with PIMGs, T1 and H323 connections via CUCM to CUC and no ring backs.
Without some traces, it will be hard.  (its hard enough trying to find this needle)  but i suspect (or possibly) there is a command missing in the SIP gateway to provide ringback.
Here is an H323 no ringback doc also.
http://www.cisco.com/en/US/tech/tk1077/technologies_tech_note09186a0080094c33.shtml
Hope this helps!
Overall Rating: 5 (1 ratings)
Tommer Catlin Mon, 01/11/2010 - 14:46
  • Green, 3000 points or more
Have you tried to release it to a non-hunt group number to see what happens?  If its consistantly dead air, then you know its a system wide problem with CUC.
Tommer Catlin Mon, 01/11/2010 - 19:52
Just to confirm, it is in fact ringing the phone on transfer right?
Tommer Catlin Mon, 01/11/2010 - 20:05
sorry for the questions....  I should have added some more in.
SCCP voicemail ports between CUCM and CUC?
Version of CUC and CUCM?
How did the call come in?   Does it matter if the call came in through the PSTN or another IP phone?
Correct Answer
Tommer Catlin Mon, 01/11/2010 - 20:35
here is one:
Hope this helps!
Tommer Catlin Tue, 01/12/2010 - 16:41
Funny, I had to turn on the same parameter in CUCM for something similar.   I was going CUCM----h323---h323--PBX.   For whatever reason, i was not getting ring back with this.  But if I had CUCM--h323-PBX..  I had ring back and it was fine.  After digging, and IOS upgrades, downgrades, etc...  something simple like that fixed it.
Glad you are good for now!
Related Content
