01-11-2010 12:23 PM - edited 03-06-2019 09:14 AM
i have to assign a seperate default route on vlan2. Please let me know how to do that I already have a default route on Vlan 1 but dont want to use that for vlan2
01-11-2010 12:29 PM
You can't but you can use PBR (Policy Based Routing) to send vlan 2 traffic to a different next-hop.
Jon
01-11-2010 12:30 PM
How to implement that in a 3550 switch can you help.
01-11-2010 12:40 PM
Firstly your 3550 needs to be running the EMI image. If it is running the SMI image it will not support PBR.
Assuming vlan 2 is 192.168.5.0 255.255.255.0
access-list 101 permit ip 192.168.5.0 255.255.255.0 any
route-map PBR permit 10
match ip address 101
set ip next-hop
int vlan 2
ip policy route-map PBR
The above config will send ALL traffic from vlan 2 to the next-hop IP address in the above config.
If you only want to send some traffic then you need to be more specific in your acl.
Jon
01-11-2010 01:12 PM
Cisco IOS Software, C3550 Software (C3550-IPSERVICESK9-M), Version 12.2(35)SE, R
ELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Sun 03-Dec-06 14:34 by yenanh
Image text-base: 0x00003000, data-base: 0x00E85C24
ROM: Bootstrap program is C3550 boot loader
MIXIT_Switch1 uptime is 5 days, 1 hour, 59 minutes
System restarted at 13:50:32 Eastern Wed Jan 6 2010
System image file is "flash:c3550-ipservicesk9-mz.122-35.SE/c3550-ipservicesk9-m
z.122-35.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. WS-C3550-48 (PowerPC) processor (revision L0) with 65526K/8192K bytes of m
emory.
Processor board ID CAT0812X0WX
Last reset from warm-reset
Running Layer2/3 Switching Image
If
Cisco
48 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
384K bytes of flash-simulated NVRAM.
Base ethernet MAC Address: 00:0F:8F:E9:63:80
Motherboard assembly number: 73-5701-09
Power supply part number: 34-0967-02
Motherboard serial number: CAT08120A28
Power supply serial number: LIT080602QF
Model revision number: L0
Motherboard revision number: A0
Model number: WS-C3550-48-SMI
System serial number: CAT0812X0WX
Configuration register is 0x10F
Thats the version which I have.Can you let me know if PBR works in it
01-11-2010 01:23 PM
Yes this should support PBR.
Jon
01-11-2010 04:33 PM
Jon is correct in his answer. Here is a link which will run down the flexability you have with PBR.
