Ok..so I seem to have the TAC befuddled so I'm going to come here as well.
I have a 6509 with a CSM blade and a SSL-M blade installed. The CSM is configured and working properly in a one-arm mode and we are tring to get the SSL-M integrated into the flow. I can get the SSL-M to present the certificate, but response flow from the server REAL back to the client is getting hung it appears. Even outside of talking through the CSM, the SSL-M does not seem to be functioning correctly. I think if I can get the SSL-M to just return traffic from a server REAL through to the client, the CSM integration would then be fall down. Can someone help me with this as I am obviously missing something. SSL-M is running 3.1(4). The server real responds on port 81 and I can telnet to the port from the SSL-M. If someone wants more of the config, I will attach it. Right now I just want traffic to flow correctly through the SSL-M, I'll integrate the CSM into the mix later.
Some config information:
Begin 6500 CONFIG CLIP
interface Vlan4 **Vlan the SSL-M is connected to on MSFC**
ip address 10.4.0.1 255.255.0.0
ip flow ingress
end
interface Vlan80 **Vlan the server is connected to on MSFC**
ip address 10.80.0.1 255.255.0.0
ip flow ingress
end
Begin SSL-M CONFIG CLIP
ssl-proxy context Default
service SSLTEST
virtual ipaddr 10.80.110.214 protocol tcp port 4443
server ipaddr 10.80.100.214 protocol tcp port 81
certificate rsa general-purpose trustpoint windows-iis6
inservice
interface SSL-Proxy0
no ip address
no ip route-cache
hold-queue 2048 in
interface SSL-Proxy0.1
encapsulation dot1Q 4
ip address 10.4.1.10 255.255.0.0
no ip route-cache
interface SSL-Proxy0.80
encapsulation dot1Q 80
ip address 10.80.0.254 255.255.0.0
no ip route-cache
ip classless
ip route 0.0.0.0 0.0.0.0 10.4.0.1
Begin Server Network Config info
IP address 10.80.100.214/16
Default gateway 10.80.0.1 (Vlan of MSFC)
