SIP Trunk on CUCM7
Jan 11th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin-top:0cm; mso-para-margin-right:0cm; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0cm; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I am stuck on a seemingly the simple solution.
I have CUCM 7 with H323 Voice Gateway which terminate PSTN connection.
We took the SIP link from the local ISP and now I want to connect CUCM directly to the SIP trunk. In front of H323 GW  I have the ASA. I made a SIP trunk on CUCM and also Route Pattern and NAT on the ASA, where I NAT a public IP that my ISP gave me to a private IP of my CUCM.
Neither outgoing nor incoming calls do not work.
Does anyone had a need for similar task, or maybe knows a solution for this problem.
armingojak Mon, 01/11/2010 - 13:29
Also to mention that my ISP provided me only IP data and telephone numbering. No username and password for authentication, and I supposed that it authenticate using IP address only.
