Blocking STARTTLS on a PIX 515 (8.0.4)
My service provider just enabled TLS on their end.  Because of this, our scanning appliances do not work correctly are the SMTP channel is encrypted.  Is there a way on the PIX that I can block the STARTTLS SMTP command?  This way I don't have to do anything with my email server or service provider.  I am currently not using "inspect" for SMTP as the default policy was causing issues with my provider.  Can I set up an "inspect" policy that just blocks STARTTLS and nothing else (not even checking anything else)?
Panos Kampanakis Mon, 01/11/2010 - 17:45
On the ASA you allow tls in esmtp inspection, but not actually block it. The inspection will block it by default though.
So you have 2 options:
- enable inspection
- have an IPS or router device with FPM match on the STARTTLS command payload to block it (you need to check where that is) in order to callibrate the method).
I hope it helps.
Related Content
