CME: Force an IP Phone to dial to a specific voice-port
Answered Question
Jan 11th, 2010
Greetings,
How can I get an IP Phone to dial out using a specific voice-port or voice-ports?
David
Correct Answer by Brandon Buffin about 7 years 2 months ago
See the following link for an explanation and sample config.
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801bc341.shtml
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 01/12/2010 - 04:04
  • Hall of Fame,
    Founding Member
Add a dedicated DN for picking the desired line, and put it on dedicated lines button.
Then, use the "trunk" command in ephone-dn, and match that number in a pots DP with the desired port..
