how can get all snmp data from cat6500??
Jan 11th, 2010
hi all,
I would like to get all snmp data from cat6500.
as i know, to get snmp data from
1. download mib of the cat6500 (using "mib locator tool" in
2. excute the snmp (viewer) application, and check the specific snmp data i want(ex. 5 sec cpu usage, memeory usage and so on...)
above fashion, i can check the specific snmp data.
if i want every snmp data from the device(cat6500), i should download every mib of the cat6500.
is there any easy method to get full-snmp data from the device??
Ganesh Hariharan Mon, 01/11/2010 - 22:41
To collect data from specifci devices MIB are the only source which will fetch the data from the devices and produce you in Graphical format.So my suggestion is the MIB for the device which will produce all data as required.
