https port-forwarding
Jan 12th, 2010
Dear The Expert,
I am trying to https (443) port-forwarding.. tried below, but not working ;>(
static (inside,outside) tcp X.X.X.X https I.I.I.I https netmask 255.255.255.255 0
access-list inbound_filter permit tcp any host X.X.X.X eq https
clear xlate
wr m
what I missed? .. is there any difference method for doing https port-forwarding?
many thanks..
regards
Winanjaya
Joe B Danford Tue, 01/12/2010 - 06:14
  • Cisco Employee,
That is right. Did you see any increments on the ACL?
Panos Kampanakis Tue, 01/12/2010 - 13:13
  • Cisco Employee,
XXX should be your global ip and III should be your local.
Check the mask that you have in the static also, did you mean 255.255.255.255?
I hope it helps.
PK
