https port-forwarding
Jan 12th, 2010
I am trying to https (443) port-forwarding.. tried below, but not working ;>(
static (inside,outside) tcp X.X.X.X https I.I.I.I https netmask 255.255.255.255 0 0
access-list inbound_filter permit tcp any host X.X.X.X eq https
clear xlate
wr m
what I missed? .. is there any difference method for doing https port-forwarding?
trustcisco Tue, 01/12/2010 - 00:31
The configuration is correct.
Is the https service running on the server ?
Ganesh Hariharan Tue, 01/12/2010 - 01:46
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Check out the https services are running or not !!
Ganesh.H
sainair Tue, 01/12/2010 - 16:05
Is the access-list inbound_filter applied to the outside interface.
Check for the command: access-group inbound_filter in interface outside
If the above mentioned command is present with the configuration that you mentioned, then you need to check the https services on the server. Also, check if you see hit counts on the access-list.
Sai
Kureli Sankar Tue, 01/12/2010 - 16:34
  • Cisco Employee,
What is the IP address? Is it the interface IP address? If so you need to use the keyword "interface" and not IP address x.x.x.x.
If it is the interface then do you have asdm enabled on the same port? If so, this traffic is destined TO the box and not THROUGH the box.
-KS
winanjaya Tue, 01/12/2010 - 16:51
Hello all,
Thanks a lot!.. this already resolved.. the problem occurs because the http server not configured correctly..
regards
Winanjaya
