Config restoration in 6509 Cisco Switch
Jan 12th, 2010
Hi, I have one 6509 series cisco switch having one Sup card. The problem is SUP is failed and I have replaced the new sup.
Now I have to restore the configuration in Sup having many passwords for EIGRP, NTP, HSRP & BGP.
What is the best way to restore so that I can get no any duplicity in the passwords.
Rupesh
Rupesh Kashyap Tue, 01/12/2010 - 03:53
Hi, this link is for IOS. I have already IOS, I want to copy start-up-cong file. How can I do it.
Ganesh Hariharan Tue, 01/12/2010 - 04:05
Hi Rupesh,
On some of the newer IOS versions you can also use the command "copy ftp: startup-config" instead, but if your IOS only supports TFTP you will have to use "copy tftp: startup-config". Now if you have a CAT OS on the 6509, very likly if it's an older 6509, you will have to use the command "write network all" to copy the config to a TFTP server.
and more detail procedure jsut check out the link hopw that helps out your query !!
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml
Ganesh.H
