Unable to Add 7942 IP Phone
Jan 12th, 2010
Dear all,
My Call Manager version is 4.1(3)sr5b. I have tried to add 7942 phone firmware to the Call manager according to Cisco provided installation procedure.
After the EXE run and service restarted, I could find the Cisco 7942 on the list box under device-->phone when searching for device type.
How ever, when I tried to add phone, Cisco 7942 was not on the list.
Please kindly help.
Thanks in advance.
Toe
Rob Huffman Tue, 01/12/2010 - 05:22
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Toe,
When you mention adding the new firmware, was it via a new Device Pak?
If so, you  would need to schedule a time to give this a try. There is a need to ***reboot when adding support for a "new" device type;
Procedure
NOTE: Apply this patch to all of your Cisco CallManager servers, beginning with the publisher server and TFTP server.
**When applying this Device Package to enable new device support, a cluster-wide reboot is required for those devices to register successfully.   A clusterwide reboot IS NOT required when running to update existing firmware/support.
If installing on a Cisco Unified CallManager version earlier than 4.1(3)sr2, the following message will be displayed: “Install on all nodes is required.  All nodes will be rebooted as part of the installation.
If installing on Cisco Unified CallManager 4.1(3)sr2 (recommended), the following message will be displayed: "Install on Publisher and TFTP server is required.  Installation on all nodes is highly recommended."   ***A clusterwide install/reboot is required.
From these older Device Pack Notes (this would be for your DevPak as well
http://ftp-sj.cisco.com/cisco/crypto/3DES/voice/callmgr/4.1/ciscocm.4-1-DevPack-43_readme.htm
Hope this helps!
Rob
