no radius accounting when redundancy inter-device configured
Jan 12th, 2010
IOS 12.4T: no radius accounting when redundancy inter-device is configured
Even the redundancy protocol is not configured with any profile, the effect of having redundancy inter-device configured as a config parameter end in suppressed radius requests. Can be verified with debug aaa accounting
*Jan 11 23:21:37.475: AAA/ACCT(00000003): Accouting method=CRYPTO-ACS-NEW (RADIUS)
*Jan 11 23:21:37.475: AAA/ACCT/EXEC(00000003): Suppressed record
The command can not be removed with the "no" option. Config must be manually modfied and copied to start-up.
TEST-FSI-3825#sho radius stat
                                  Auth.      Acct.       Both
         Maximum inQ length:         NA         NA          0
       Maximum waitQ length:         NA         NA          0
       Maximum doneQ length:         NA         NA          0
       Total responses seen:          0          0          0
     Packets with responses:          0          0          0
  Packets without responses:          0          0          0
  Access Rejects           :          0
Average response delay(ms):          0          0          0
Maximum response delay(ms):          0          0          0
  Number of Radius timeouts:          0          0          0
       Duplicate ID detects:          0          0          0
Buffer Allocation Failures:          0          0          0
Maximum Buffer Size (bytes):          0          0          0
Malformed Responses        :          0          0          0
Bad Authenticators         :          0          0          0
Unknown Responses          :          0          0          0
1 vote
