ASA 5510 Interface errors
Jan 12th, 2010
Dear ALL,
I have a Cisco ASA 5510 as firewall which is directly connected to a Cisco 2600 series router (this is supplied by ISP) .
ASA's outside is connected to router's interface by a patch cable.
Every thing seems to run properly but I experienced too many errors on outside.
For example, within 48 hours period, I can get this situation:
112.815 collisions
34.631 late collisions
780.866 deferred
ISP told me his interface has been set to 10 Mb full duplex, but if I set up outside to auto auto I can get 10 Mb half-duplex
Please, anyone of you could give me an help?
                                   Alberto Brivio
Joe B Danford Tue, 01/12/2010 - 06:32
Did you try setting the ASA to 10 Full? If one side is hard coded you should do the same to the ASA also.
albertobrivio42 Tue, 01/12/2010 - 07:02
I tried to set.
But if I set up full or half duplex, it doesn't run
If I set up auto , it automatically set up to half-duplex, and runs.
Joe B Danford Tue, 01/12/2010 - 10:53
Try setting to full then bring the interface down and back up. I know of a similar issue with same hardware. May want to try rebooting the router also.
albertobrivio42 Thu, 01/14/2010 - 03:50
Solution was replace patch cable with a cross cable.
I can see 10 Mb full duplex correctly without any error interface.
                                    Thanks for your help
