01-12-2010 01:55 AM
I have problem with some devices (in fact IP addresses) that was discovered and used by RME in the past but are not reachable anymore. They spoil statistics in RME (collection of inventory and configuration) however they do not exist in DCR. Do you have any ideas how to get rid of them?
RME: 4.2.0
CS: 3.2.0
01-12-2010 09:59 AM
Is LMS integrated with ACS?
01-13-2010 02:56 AM
Yes, LMS is integrated with ACS solution engine v4.2
01-13-2010 09:22 AM
Check Common Services > Device and Credentials > Reports > Devices not configured in ACS to see if your devices show up there. If they do, then you will need to either add those devices to ACS (temporarily) so you can remove them from DCR; or you will need to temporarily disable ACS integration, remove the devices from DCR, then re-enable integration.
