what next after CCNA
Answered Question
Jan 12th, 2010
i have completed my CCNA(ICND1 and ICND2) and
wants to go to CCSP path. which exam i should give next.
Correct Answer by LordFlasheart about 7 years 1 month ago
The prerequisites for CCSP are:
CCNA Security OR CCNA + SND (up to Nov. 2011) OR any CCIE Certification can act as a pre-requisite.
I'm assuming you are not going down the CCIE track and you can't take SND anymore I believe so that means you need to complete the CCNA Security exam before taking CCSP. After that I would take SNRS.
Good luck!
Please rate if helpful.
Overall Rating: 5 (1 ratings)
Correct Answer
LordFlasheart Tue, 01/12/2010 - 03:03
Good luck!
nitin mohan Tue, 01/12/2010 - 03:08
as you have mentioned if i take SND before NOV , i would be fine or not ?
you know for sure SP is your track? the decision is step 1
if it is your path you should do your CCNA+security as it is required for the SP
I would wait few days to see the details of the new NP, I didn't read about any planned changed but since it should be announced this month I would wait just to make sure nothing is changing on the SP track
good luck
Rofi Neron @ ITDualism.wordpress.com
