LMS 3.2 - snmp-write needed ?
Jan 12th, 2010
we are testing currently LMS 3.2 for a very large installation. In our network snmp-write access to devices is currently forbidden by a special company policy. The devices can only contacted via snmp-read and telnet/ssh.
So my questions is:
For which functions does LMS 3.2 realy need snmp-write access to the devices ? Or can I use telnet/ssh intead of snmp-write always ?
Thx + Best regards
Michel Hegeraat Fri, 01/15/2010 - 06:23
I believe only IPM need snmp write to program the collectors.
So apart from that you should be fine with RO and telnet/ssh access
Joe Clarke Sat, 01/16/2010 - 22:29
CiscoView also requires the SNMP read-write for most its configuration tasks (some can use telnet/SSH).  This is not nearly as show-stopping as IPM, though.  IPM is pretty much useless without SNMP read-write.  But note, that community string-based SNMP is no longer required in LMS.  You can move to SNMPv3, and be able to do SET operations in a more secure manner.
