LordFlasheart Tue, 01/12/2010 - 03:11
The main page for it is now at http://www.cisco.com/cisco/web/support/index.html
From there choose the Cisco IOS and NX-OS Software option in Option 1. Go through and choose your IOS of choice depending on the CCIE blueprint. Once through, the two main sections are the Command References and the Configuration Guides.
Good luck with your stuides!
Please rate if helpful.
Shervan Singh Tue, 01/12/2010 - 04:18
Thanks,  but what I wanted to know was if there was a link to the CD itself which has all of
the content.
Much appreciated
LordFlasheart Tue, 01/12/2010 - 04:25
Not sure if you can order the DVD now. Absolutely everything you need to know are in those web pages that I have pointed you too. Check out Internetwork Experts free CoD for navigating the Cisco DocCD.
The DocCD name is a little confusing as well as it just refers to the online documentation now.
guibarati Wed, 02/23/2011 - 14:48
I know there is a while since your post, but, have you ended finding a url for the exact material available in the lab?
