N5000 & ICMP Rate Limit
Answered Question
Jan 12th, 2010
  • Bronze, 100 points or more
All,
Does the N5000 run an ICMP rate limiter by default ?
I just connected a N5000 up to a C6500 chassis. When i ping the N5000 (inline ! on a SVI interface) from the C6500, he drops everytime the 95th ping request :-)
TESTC6500#   ping 10.102.78.66 df-bit size 1500 repeat 100
Sending 100, 1500-byte ICMP Echos to 10.102.78.66, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 99 percent (99/100), round-trip min/avg/max = 1/1/4 ms
TESTC6500#
Correct Answer by johgill about 7 years 5 months ago
There is no (configurable) rate-limiter function in the N5k.  I think what you are seeing is a result of process/scheduler timing, but I would have to look up some tests to back that up.
I can do the same operation and I see the packet mising is either 95, 96, none, 97... it varies.  With a true rate-limiter, you will typically see a much more defined pattern.
The Nexus 7000 has hardware and software control-plane policing (CoPP), but the Nexus 5000 does not.  I think it's possible you will see software CoPP in the Nexus 5000 in the future, but time will tell.
John Gill
Overall Rating: 5 (1 ratings)
Correct Answer
johgill Tue, 01/12/2010 - 18:32
John Gill
