Hossain Ahmed A... Mon, 04/05/2010 - 04:35
  • Bronze, 100 points or more
MGCP can not be used with AS5350/5400XM. You need to use H323 for this. Here is the list of MGCP supported VoiceGateways
Cisco Voice Gateway 200 (VG200)
VG224 Gateway
Cisco IOS 269X, 26XX, 362X, 364X, 366X, 3725, 3745 Gateways
Cisco 2801, 2811, 2821, 2851, 3825, 3845 Gateways
Cisco Catalyst 4000 Access Gateway Module
Cisco Catalyst 4224 Voice Gateway Switch
Communication Media Module
Cisco IAD2400
Md. Mijanur Rahman Mon, 04/05/2010 - 04:43
Hi, AS53XX/54XX supports MGCP but unfortunately not with CUCM so far. Only Cisco PGW/BTS and some third-party solutions can talk with them via MGCP but I don't know why Cisco is still restricting them to use with CUCM. I also found these AS series universal voice gateways doesn't support RSVP as well, what a crap! But you can see all these on it's supported features!
Hossain Ahmed A... Mon, 04/05/2010 - 05:05
Thanks for the info, I know that AS53XX/54XX supports MGCP. But my answer was according to your question "AS5350 and CUCM MGCP, can I?" That why I was suggesting you to use h323 in AS5350 so that u can use it with CUCM.
Related Content
