CUCM-BE 7.1.3 Cannot export phone Specific Details
Answered Question
Jan 12th, 2010
I recently installed CUCM-BE 7.1.3 and have found that after adding phones that I cannot export phones with Specific details.  I can look at the Job request listing as "complete, but the Job Results information is blank below the header.
If I export All Details I can pull down the file, but is basically useless due to there are to many fields for Excel to load properly.
I have exported the same specific details with CUCM 6.1.2 and worked fine.  The problem has occured with 7.1.3-20000 and 7.1.3-31900, so far.
Anyone else experience this issue?  If so are you using a customer phone information or one of the generics?
Correct Answer by Rob Huffman about 7 years 5 months ago
Hi John,
It sounds like you may be hitting this bug;
CSCtb95233 Bug Details Bug #29 of 96 | < Previous | Next >
Bulk Administration Phone Export
Symptom:
When attempting to use Bulk Administration->Phones->Export Phones->Specific Details after selecting your phones to export if you choose a custom custom made file format and not one of the Cisco defaults and run the job, in the job status screen it will immediately say "complete" but the job never ran and no file is exported.
Conditions:
Exporting phones with specific details via BAT using a custom file format.
It is caused by the "Owner User ID" column in the file format chosen.
Workaround:
use a file format without "Owner User ID" column in the file format chosen
Status
Fixed
Severity
3 - moderate
Last Modified
In Last month
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
7.1(2.39111.4)
Fixed-In
7.1(4.98000.44)
7.1(3.21008.1)
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
Rob Huffman Tue, 01/12/2010 - 06:38
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi John,
Symptom:
Conditions:
Workaround:
Status
Fixed
Severity
3 - moderate
Last Modified
In Last month
Product
Technology
1st Found-In
7.1(2.39111.4)
Fixed-In
7.1(4.98000.44)
7.1(3.21008.1)
Hope this helps!
Rob
bnstxjohn Tue, 01/12/2010 - 09:33
That worked perfectly!!!  The TAC engineer could not figure that one out.
Thank you very much.
Related Content
