jamccord Wed, 01/20/2010 - 07:39
Can you be more specific as to the layout you or topology you are referring to?  I want to make sure I fully understand your question.
Steven Smith Mon, 04/12/2010 - 07:36
  • Gold, 750 points or more
This is not supported.  The clustering is only for AP541Ns.  The SA520W can not be configured to work in a cluster today.
Steve,
Thanks for the prompt answer. I don't see the feature and it is a dissapointment, so much for SMB equipment integration. It is interesting that the documentation states under the "Factory Default Settings" that ;
Clustering of Access Points - unique to AP54x - disabled
so it makes me think that the capability is intended but hidden. Perhaps for a later release. I am able to semi-cluster the SA520w with the AP541n's simply by using the same SSID's and VLAN tags. Do you see any problems with that arrangement or should I just turn off the SA520w radio.
stef.Andries Tue, 09/07/2010 - 04:43
Hi there,
same question here: when (if ever) will Cisco support WPS linking with AF541N access points ?
Disabling WIFI on the SA520W is a bit silly, since we bought this box ust because of the included WIFI support...
Cisco, please advise.
sbommaji Fri, 09/17/2010 - 09:35
SA520w-k9 cannot be clustered with AP541N. Clustering feature is supported only between AP541N devices. Also WDS cannot be configured between a AP541N and SA520W-k9.
Sunil
