issue with CCM 5.1 integration with Genesys T-Server and GVP
Jan 12th, 2010
I´ve a CCM cluster 5.1 integrated with Genesys T-Server and GVP working ok, but there is an issue in this case:
1.- The call arrives from GW directly to route point (0010) controlled by T-Server
2.- When the agent receives the call, and make a transfer to 0019, which is a route pattern pointing to GW, and on GW 0019 is a dial peer pointing to GVP with SIP.
3.- GVP receives that call, and when the caller use an option that makes a transfer to 0012 which is another Route Point controlled by T-Server, the call established but it gets one way audio on the caller.
I´ve tried using a GW between the GVP and the 0012,but I get the same issue.
So there is a way to correct this? I cannot change more parameters on Route Point configuration, I think is a problem on the call control of the Genesys servers.
Please let me know.
Andres Pasten
Adexus S.A.
ahmadj1973 Wed, 08/04/2010 - 04:13
Is any body have a solution for that, I have the same problem with CCM6.1.
Thanx in advance,
MJ
andres.pasten Wed, 08/04/2010 - 05:24
In my case the Genesys engineers decided to not use that config, because there is no formal documentation that indicates that is allowed or supported.
Andres
