01-07-2010 06:48 AM - edited 03-06-2019 09:11 AM
since two weeks i have my switch1 (2960G 48 port) who get (receive) a lot of FCS errors on the port who is pluged to my another 2960G(who don't display any fcs error ) and every server who is pluged on my two switchs drop packets , get sql,http,network problem and are very slow...etc
I'am going crazy , i have used many differents cable (shielded cat6) used on many differents ports(on both switchs) , i have trying the follow configuration on my two ports:
switchport trunk allowed vlan 3,101,102,104
switchport mode trunk
switchport nonegotiate
channel-group 1 mode active (etherchannel in lacp mode both port active , same priority)
spanning-tree portfast
speed 1000
In this case the port don't work
duplex full
but nothing solve my probleme ,
i have checked controller with show controllers ethernet-controller phy , all are good.
sometime i see the cpu at 80% but when i do show processes cpu sorted all process are at 2% cpu used max....
i have of course restart the switch and i am out of idea.
If you have some that would be nice thanks you.
ps: sorry for my english
01-07-2010 07:21 AM
Hello Christophe,
Can you post "sh run" from both switches?
Reza
01-07-2010 07:31 AM
for switch1 (who show error fcs in receive)
Using 6515 out of 65536 bytes
version 12.2
no service pad
service timestamps debug datetime msec localtime
service timestamps log datetime msec localtime
service password-encryption
service sequence-numbers
hostname Th2-sw1
enable secret 5 $1$D1GE$Jcz0cTs5PRfNq8fttlKvh0
username AdmCisco password 7 044F0E0A0A2243435B49554E5C
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone UTC 1
clock summer-time UTC recurring last Sun Mar 2:00 last Sun Oct 2:00
system mtu routing 1500
vtp mode transparent
ip subnet-zero
ip domain-name budgetelecom.com
no file verify auto
spanning-tree mode pvst
spanning-tree vlan 1-1000 priority 45056
vlan internal allocation policy ascending
vlan 3
name rouge
vlan 101
name bleu
vlan 102
name vert
vlan 103
vlan 104
name rose
interface Port-channel1
interface GigabitEthernet0/1
switchport trunk allowed vlan 102
interface GigabitEthernet0/2
interface GigabitEthernet0/3
interface GigabitEthernet0/4
switchport access vlan 102
switchport mode access
interface GigabitEthernet0/5
interface GigabitEthernet0/6
interface GigabitEthernet0/7
interface GigabitEthernet0/8
interface GigabitEthernet0/9
interface GigabitEthernet0/10
interface GigabitEthernet0/11
interface GigabitEthernet0/12
interface GigabitEthernet0/13
interface GigabitEthernet0/14
interface GigabitEthernet0/15
interface GigabitEthernet0/16
interface GigabitEthernet0/17
switchport access vlan 3
interface GigabitEthernet0/18
interface GigabitEthernet0/19
interface GigabitEthernet0/20
interface GigabitEthernet0/21
interface GigabitEthernet0/22
interface GigabitEthernet0/23
interface GigabitEthernet0/24
interface GigabitEthernet0/25
interface GigabitEthernet0/26
switchport access vlan 101
interface GigabitEthernet0/27
load-interval 30
interface GigabitEthernet0/28
interface GigabitEthernet0/29
switchport access vlan 104
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
duplex full
interface GigabitEthernet0/41
speed 1000
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface Vlan1
no ip address
no ip route-cache
interface Vlan102
ip address 10.2.2.247 255.255.255.0
no ip route-cache
ip default-gateway 10.2.2.250
ip http server
no cdp run
snmp-server community th2-sw1 RO
snmp-server location TH2
snmp-server contact julien vincent
radius-server source-ports 1645-1646
control-plane
line con 0
line vty 0 4
password 7 03105E07030C2E411C59495C59
line vty 5 15
end
Th2-sw1#
for my second switch (who don't display any error)
show conf
Using 6592 out of 65536 bytes
version 12.2
no service pad
hostname Th2-sw2
aaa new-model
ip subnet-zero
no file verify auto
spanning-tree vlan 1-1000 priority 49152
vlan 3
name rouge
vlan 100
vlan 101
name bleu
vlan 102
name vert
vlan 104
name rose
shutdown
spanning-tree bpdufilter enable
load-interval 30
duplex full
speed 1000
switchport access vlan 100
speed 100
shutdown
interface Vlan1
no ip address
no ip route-cache
shutdown
interface Vlan102
ip address 10.2.2.248 255.255.255.0
no ip route-cache
ip http server
no cdp run
snmp-server community th2-sw2 RO
control-plane
line con 0
line vty 5 15
end
Th2-sw2#
01-07-2010 08:39 AM
FCS (Frame Check Sequence) is calculated on frames received/sent over ethernet to check for frame's correctness.
I understand that in your network you are experiencing packet drops and latency. First of all FCS errors are caused due to layer two issues mostly mismatch of duplex on both ends of links. Say, you have this end of link running at 100 FULL but other end is wokring at 100 HALF, then it will cause some serious drops/slowness etc.
.I have included a link below to help you troubleshoot ethernet issues :
http://www.cisco.com/en/US/tech/tk389/tk214/technologies_tech_note09186a0080094781.shtml
Again, coming back to your issue of slowness, you need to have a look at the detailed topology diagram, and do pings from one point of n/w to other end, and keep a note of RTT and go on measuring latency, until you come up with the bottleneck device.
Latency issues generally require lot fo detailed troubleshooting, whihc maybe out of scope of discussion forums. Try to open a TAC case with Cisco.
Vijaya
01-11-2010 08:46 AM
i don't understand vijaya when you say ", you have this end of link running at 100 FULL but other end is wokring at 100 HALF"
all server and switch are in full duplex .
Btw a things very strange happended when i force the full duplex mode or speed 1000 on port between my two switch , the ports are down, they didn't lighting , but in nonegotiate mode i 'am in full duplex /1000 and it's work...
01-07-2010 01:06 PM
May I request if you post the output for "sh controll ether
01-11-2010 08:19 AM
Transmit GigabitEthernet0/46 Receive
2180367708 Bytes 3940032344 Bytes
47689370 Unicast frames 26142784 Unicast frames
296 Multicast frames 450702 Multicast frames
28338 Broadcast frames 10408 Broadcast frames
0 Too old frames 3721317512 Unicast bytes
0 Deferred frames 109857300 Multicast bytes
0 MTU exceeded frames 742638 Broadcast bytes
0 1 collision frames 0 Alignment errors
0 2 collision frames 6430 FCS errors
0 3 collision frames 0 Oversize frames
0 4 collision frames 0 Undersize frames
0 5 collision frames 0 Collision fragments
0 6 collision frames
0 7 collision frames 1343003 Minimum size frames
0 8 collision frames 14032299 65 to 127 byte frames
0 9 collision frames 10961750 128 to 255 byte frames
0 10 collision frames 73759 256 to 511 byte frames
0 11 collision frames 85283 512 to 1023 byte frames
0 12 collision frames 114082 1024 to 1518 byte frames
0 13 collision frames 0 Overrun frames
0 14 collision frames 0 Pause frames
0 15 collision frames
0 Excessive collisions 0 Symbol error frames
0 Late collisions 147 Invalid frames, too large
0 VLAN discard frames 0 Valid frames, too large
0 Excess defer frames 0 Invalid frames, too small
277014 64 byte frames 0 Valid frames, too small
34717043 127 byte frames
12051460 255 byte frames 0 Too old frames
199447 511 byte frames 0 Valid oversize frames
171916 1023 byte frames 0 System FCS error frames
301124 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
0 Good (1 coll) frames
0 Good (>1 coll) frames
Transmit GigabitEthernet0/45 Receive
545502922 Bytes 2020889009 Bytes
1850392 Unicast frames 18063342 Unicast frames
25102 Multicast frames 32865 Multicast frames
12931 Broadcast frames 17497 Broadcast frames
0 Too old frames 1921081200 Unicast bytes
0 Deferred frames 25785242 Multicast bytes
0 MTU exceeded frames 1240783 Broadcast bytes
0 2 collision frames 1091 FCS errors
0 7 collision frames 945594 Minimum size frames
0 8 collision frames 14812695 65 to 127 byte frames
0 9 collision frames 1836665 128 to 255 byte frames
0 10 collision frames 109579 256 to 511 byte frames
0 11 collision frames 375904 512 to 1023 byte frames
0 12 collision frames 34349 1024 to 1518 byte frames
0 Late collisions 9 Invalid frames, too large
131735 64 byte frames 0 Valid frames, too small
304587 127 byte frames
1263597 255 byte frames 0 Too old frames
30046 511 byte frames 0 Valid oversize frames
20675 1023 byte frames 0 System FCS error frames
137785 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
Th2-sw1#
for the switch who get error
and for the second i have
3259224661 Bytes 2129159225 Bytes
677223805 Unicast frames 1262545270 Unicast frames
11225778 Multicast frames 93558 Multicast frames
472958 Broadcast frames 1294370 Broadcast frames
0 Too old frames 1265926740 Unicast bytes
0 Deferred frames 7930105 Multicast bytes
0 MTU exceeded frames 94591776 Broadcast bytes
0 2 collision frames 0 FCS errors
0 7 collision frames 5153758 Minimum size frames
0 8 collision frames 881994930 65 to 127 byte frames
0 9 collision frames 245097460 128 to 255 byte frames
0 10 collision frames 2975451 256 to 511 byte frames
0 11 collision frames 3304493 512 to 1023 byte frames
0 12 collision frames 125407108 1024 to 1518 byte frames
0 Late collisions 0 Invalid frames, too large
72944368 64 byte frames 0 Valid frames, too small
375706316 127 byte frames
226725474 255 byte frames 0 Too old frames
2291995 511 byte frames 0 Valid oversize frames
2406526 1023 byte frames 147249 System FCS error frames
8995111 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
3641953495 Bytes 1738593180 Bytes
451916607 Unicast frames 41939995 Unicast frames
1162444 Multicast frames 1401042 Multicast frames
765887 Broadcast frames 593499 Broadcast frames
0 Too old frames 394510278 Unicast bytes
0 Deferred frames 1120983217 Multicast bytes
0 MTU exceeded frames 47415981 Broadcast bytes
0 7 collision frames 6871026 Minimum size frames
0 8 collision frames 9769443 65 to 127 byte frames
0 9 collision frames 13195624 128 to 255 byte frames
0 10 collision frames 1141116 256 to 511 byte frames
0 11 collision frames 756668 512 to 1023 byte frames
0 12 collision frames 12200659 1024 to 1518 byte frames
19677205 64 byte frames 0 Valid frames, too small
388530969 127 byte frames
27924970 255 byte frames 0 Too old frames
1690667 511 byte frames 0 Valid oversize frames
15027983 1023 byte frames 21087 System FCS error frames
1014231 1518 byte frames 0 RxPortFifoFull drop frame
0 Too large frames
Th2-sw2#
01-11-2010 09:32 AM
You can't hardcode the speeds because mdix-auto is on for your ports . if you want to try and hardcode the ports then on the ports enter "no mdix-auto". Ports will only work in auto when this is turned on .
01-12-2010 12:00 AM
if you look the conf you will see i have forced the speed and fullduplex on port 40 and 41 (no mdix)
01-11-2010 01:50 PM
GigabiEthernet0/45 and 46 has high FCS errors. Since FCS are normally found in the "receive" side, look at the switch with no errors and concentrate there. Try moving to a different ports.
Worst case scenario: Try using the 2960's Time Domain Reflectometer (TDR) to test the cabling.
Warning: TDR testing is disruptive.
01-12-2010 12:08 AM
Maybe i have forgoten to say that but i have tested the connection between my switchs on seven differents port and method (3--3,38---38,40--40,41--41,47--47,48--48 and actually 45-46--45-46) i have already tested (test cable-diagnostics tdr interface gigabitEthernet 0/X) and change the cabling six times .
01-12-2010 03:07 AM
I following your advice and after looking on switch who have no probleme(his name is th2-swi2) i see an another switch (dell powerconnect 3424 , his name is gbswi04) recieve error on the port who is pluged on th2-swi2(the switch who don't show error) , i see on my th2-swi2 btw a lot of undersize packet incomming from my firewall (asa 5510) do you think that can be generate fcs error on th1-swi1 (the switch who receive error) even if is not directly pluged on my firewall?
01-12-2010 03:40 AM
A switch will not pass through FCS (or any other) error frames. Undersize packets will be dropped by the switch.
Pete
01-12-2010 06:52 AM
look like it's th2-swi2 the switch who didn't display any error who is the problem...
But how i can monitor that? (all controller /process/packets/cable/ports are looking good,already try to change the ports and the conf)
