01-12-2010 06:57 AM - edited 03-21-2019 02:00 AM
I've got a UC520 connected to an ESW540, which is then connected to another ESW540 in another building by a fibre link. The fibre link is run through two 3Com Surestack switches (old), while we wait for new fibre cables to link the ESWs directly.
Using CCA I can see the remote ESW and configure it. Client PCs are conected and working fine, but IP phones (SPA525G and SPA504G) do not pick up an IP address. I am assuming that something is causing a problem with the VLans on the way over.
Is there anything I can do to prevent this? I don't mind a less than ideal solution as it should only be temporary.
Thanks.
Adam
01-12-2010 07:52 AM
IP Phones on our system must be on VLAN 100. So make sure that that VLAN is propagated across the layer 2 hops connecting both ESW switches.
Marcos
01-14-2010 01:25 PM
Fine, I think the VLans were getting stripped.
Got a new transciever today - link between ESWs works without a problem.
Thanks.
Adam
