How to upgrade the fwsm image from 3.1(10) to 4.0(8).
Jan 12th, 2010
Hi all,
I need to upgrade the fwsm image from 3.1(10) to 4.0(8). Can i do it directly from 3.1(10) to 4.0(8) ?
Do i need to upgrade other image also along with Firewall version 4.0(8)?
FWSM# sh ver
FWSM Firewall Version 3.1(10)
Device Manager Version 6.1(5)F
Compiled on Mon 21-Apr-08 17:43 by fwsmbld
FWSM up 2 days 15 hours
failover cluster up 2 days 15 hours
Hardware: WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash STI Flash 8.0.0 @ 0xc321, 20MB
0: Int: Not licensed : irq 5
1: Int: Not licensed : irq 7
2: Int: Not licensed : irq 11
The Running Activation Key is not set, using default settings:
Licensed features for this platform:
Maximum Interfaces : 256
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Cut-through Proxy : Enabled
Guards : Enabled
URL Filtering : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : Unlimited
Serial Number: SAD125004FT
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration last modified by enable_15 at 18:58:52.627 IST Mon Jan
11
2010
Madhu
Overall Rating: 3.3 (3 ratings)
Panos Kampanakis Tue, 01/12/2010 - 13:16
  • Cisco Employee,
Yes, you can upgrade from 3.1 to 4.0.
Make sure you have downtime though and if you have failover that the FWSMs are not running 3.1 and 4.0 at the same time.
I hope it helps.
PK
Kureli Sankar Tue, 01/12/2010 - 19:50
  • Cisco Employee,
Madhu,
If this is a failover pair then pls. follow this link.  zero downtime upgarde is not supported when doing a major upgrade.
once you get the code onto the blades "copy tftp flash:image" you can follow this link:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/configuration/guide/swcnfg_f.html#wp1064232
You already have the latest ASDM so, no need to upgrade that.
-KS
madhusudhan s Fri, 01/15/2010 - 04:15
Is it application partition or maintainance partion where we need to upgrade the image from 3.1(10) to 4.0.8.
Reagrds
madhu
Kureli Sankar Fri, 01/15/2010 - 05:19
  • Cisco Employee,
Application partitiion is what you will be upgrading from 3.1.(10 to 4.0(8).
MP - maintenance partition is supposed to be 2.1.2 or above which is the same requirement for 3.1.x so, you will be good there.
Pls. check the compatibility with the swtich code in this 4.0.8 Release Note link:
http://www.cisco.com/en/US/docs/security/fwsm/fwsm40/release/notes/fwsmrn40.html
Pls. check the chassis system requirement in the above link.
commands you will need are:
copy tftp flash:asdm
falsh:image for OS and flash:asdm if you will be upgrading the asdm as well.
-KS
Norberto Salgado Tue, 04/17/2012 - 04:23
Hello KS,
in the upgrade from 3.1 to 4.0.x, the nat-control feature is mantained?
Thank you.
Best regards,
Norberto
