asa multiple context snmp
Jan 12th, 2010
Can i monitor the total (all context) use of Cpu in asa with multiple context?. I can activate snmp in system context and it use 25% of cpu.
Panos Kampanakis Tue, 01/12/2010 - 13:19
snmp can be enabled on a per context basis, it is not available in the system context.
Depending on the traps and the polls you are doing it can increase the cpu.
I hope it helps.
