spa962 line monitoring blf problem
Jan 12th, 2010
hi,
I cannot configure properly a spa962 to make it monitor another phone's extension; the syntax that I've used in the phone tab > line key X > extended function is:
fnc=blf;sub=stationname@$PROXY;ext=number@$PROXY (of course I put a real number for the extension)
the led of the button key (configured as 'disabled' and 'private') is amber and does not monitor the extension.
Alberto Montilla Tue, 01/12/2010 - 08:39
Dear Sir:
Two additional basic questions/recommendations:
(1) on the sub, you need to add the station name of the other party, this is key for it to work properly
(2) Make sure you have a recent firmware.
(3) Make sure that CTI enabled is configured in the two phones and the SPA9000.
Alberto
cvaccari Wed, 01/13/2010 - 08:13
I followed all the indication, but the result is the same (amber led colour).
Alberto Montilla Wed, 01/13/2010 - 09:20
Dear Sir;
I would suggest you open a case with the Small Business Support Center, they will follow up your case in a timely fashion. You will find the contact number in the main page of this community.
Alberto
