IP Phones licensing with CallManager
Jan 12th, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Tableau Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;}
I start by wishing you all a happy new year 2010 !!
I am about to order Cisco IP Phones to be used in two locations:
Headquarter with Cisco 2851 router (with CCME: C2851-VSEC-CCME/K9)
Branch with Cisco 2821 router (with SRST : C2821-VSEC-SRST/K9)
Now I want to choose IP Phones but I am a bit confused about the licensing options:
I have IP Phones with CH1 licensing at the end of the model, meaning Call Manager and others with CCME at the end (Call Manager Express)…
Can you please explain which one is the right for all my IPPhones (Headquarter and Branch) ? also can you help understand what is the difference between these two licensing options.
Any document or link will be appreciated !
thanks
Overall Rating: 5 (1 ratings)
Tommer Catlin Tue, 01/12/2010 - 11:34
  • Green, 3000 points or more
If all phones are tied to CUCM, then you will need to purchase DLUs for CallManager to support the phones.
If you have phones using the CME at the remote site (and not CUCM) you will need th correct license for the CME at that site.
And if you are using CME+SRST you will need licenses for the CUCM (all phones) AND licenses for the CME.
coletemple Wed, 01/13/2010 - 01:59
Thanks for your reply.
My phones will be using CME at the HQ and branch.
If I am not wrong, I believe that all my phones will be using CME licence...
When ordering, I see CP-79xx-CH1 and CP-79xx-CCME. what is the difference between these two IP Phones in term of licensing ?
Which IP Phone part number do I need in my design ? (CP-79xx-CH1 or CP-79xx-CCME)
Rob Huffman Wed, 01/13/2010 - 05:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
HI Paul,
Just to tag on to the great tips from my friend Tommer (+5 TCAT)
In your deployment the correct license is;
CP-79xx-CCME
With the CCME standing for Cisco Communications Manager Express
The "old" CP-79xx-CH1 is for pre-5.x CCM deployments. After 5.x the Communications
Manager (not express) phones require DLU's (Device License Units) as Tommer nicely
pointed out.
Hope this helps! Cheers!
Rob
