Last FEAC code received: OOF
Jan 12th, 2010
When I do 'sh controllers serial 1/0' I get the OOF message at the very bottom.  I can't find much on google about this error or how to troubleshoot it.  When I clear the counters on the interface the message remains.  What is the proper way to clear this message?  Or does this mean it is an ongoing issue that can't be cleared because it continues to lose framing?  TIA
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Tue, 01/12/2010 - 10:09
  • Hall of Fame,
    Founding Member
OOF = out of frame delineation
it indicates that the receiver is not capable to recognize the frame structure caused by line code errors and/or clocking errors.
I would suggest you to post the whole sh controller serial 1/0 in the output interpreter if your CCO account has enough rights
you can find it here
https://www.cisco.com/cgi-bin/Support/OutputInterpreter/home.pl
or you can post here in the forums
Hope to help
Giuseppe
snickered Tue, 01/12/2010 - 10:22
That tool never works for me.  Here's my 'sho controllers s1/0'.
M2T-T3+ pa: show controller:
PAS unit 0, subunit 0, f/w version 3-93, rev ID 0x2800001, version 3
idb = 0x71D9D6C, ds = 0x71DAEB4, ssb=0x71DB278
Clock mux=0x30, ucmd_ctrl=0x0, port_status=0x1
Serial config=0xA, line config=0x1B0202
maxdgram=4584, bufpool=128Kb, 256 particles
   rxLOS inactive, rxLOF inactive, rxAIS inactive
   txAIS inactive, rxRAI inactive, txRAI inactive
line state: up
cable type : T3  cable, received clockrate 44201430
base0 registers=0xE0000000, base1 registers=0xE0002000
mxt_ds=0x8A7EE0C, rx ring entries=124, tx ring entries=254
statring=0x38364840, statr shadow=0x71FDB30, stat_head=289
rxring=0x38363840, rxr shadow=0x71FD4FC, rx_head=94
txring=0x384C7640, txr shadow=0x71FE764, tx_head=10, tx_tail=10, tx_count=0
throttled=0, enabled=0
halted=0, last halt reason=0
Microcode fatal errors=0
rx_no_eop_err=0, rx_no_stp_err=0, rx_no_eop_stp_err=0
rx_no_buf=0, rx_soft_overrun_err=49, dump_err= 0, bogus=0, mxt_flags=0x2C
tx_underrun_err=0, tx_soft_underrun_err=0, tx_limited=1(64)
tx_fullring=0, tx_started=1371222963, mxt_flush_count=0
rx_int_count=1551990381, tx_int_count=1371222963
   Framing is c-bit, Clock Source is Line
   Bandwidth limit is 44210, DSU mode 1, Cable length is 220
   rx FEBE since last clear counter 0, since reset 1251926
   Data in current interval (71 seconds elapsed):
     0 Line Code Violations, 0 P-bit Coding Violation
     0 C-bit Coding Violation
     0 P-bit Err Secs, 0 P-bit Sev Err Secs
     0 Sev Err Framing Secs, 0 Unavailable Secs
     0 Line Errored Secs, 0 C-bit Errored Secs, 0 C-bit Sev Err Secs
  Data in Interval 1:
  Data in Interval 2:
  Data in Interval 3:
  Data in Interval 4:
  Data in Interval 5:
  Data in Interval 6:
  Data in Interval 7:
  Data in Interval 8:
  Data in Interval 9:
  Data in Interval 10:
   Total Data (last 10 15 minute intervals):
     0 Line Code Violations, 0 P-bit Coding Violation,
     0 C-bit Coding Violation,
     0 P-bit Err Secs, 0 P-bit Sev Err Secs,
     0 Sev Err Framing Secs, 0 Unavailable Secs,
   No alarms detected.
Giuseppe Larosa Tue, 01/12/2010 - 11:28
  • Hall of Fame,
    Founding Member
Hello Snickered,
to be honest output intepreter feedback on this sh controller is poor.
I've looked for troubleshooting documents about T3 here are some links:
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008034418d.shtml#maintopic1
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a0080344194.shtml
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008034bdd8.shtml
FEAC should be far end = other side
it is a management feature actually, a link to DS3 standard explanation
DS3 remote-line loopback (via Far End Alarm and Control [FEAC] codes per American National Standards Institute [ANSI] T1.107a)
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps4909/product_data_sheet09186a008010fba2_ps282_Products_Data_Sheet.html
http://www.teracomm.com/appnotes/whitepapers/DS3%20Fundamentals.pdf
So I would see if you manage the other side you should look at the device on the other side, if you don't manage the other end of DS3 link you should contact the WAN provider.
Hope to help
Giuseppe
rigoel Tue, 01/12/2010 - 12:35
  • Cisco Employee,
Hey Snickered,
We are getting FEBE at the end of the sh controllers output and here
FEBE means Far End Bit Error.
This generally comes up when we have problems ( Circuit ) with the Provider.
Moreover , as it is not going away with the clear counters command, would really mean that we are running into Line Problems with the Provider.
At this point, the best deal here would be know the source of these errors.
Thus, I would suggest you to do a T3 Loopback Test:
During the Loopback Test the Controller t3 output should be completely clean and error free.
Here is a link to do the same:
T3 Error Events Troubleshooting and its related loopback
http://www.cisco.com/en/US/tech/tk713/tk628/technologies_tech_note09186a008034418d.shtml#maintopic4
Now, this loopback test is of two types:
#Hardware Loopback Test
#Software Loopback Test
In case, if you want to go for Hardware T3 test, then you have to make a loopbcak cable where the Tx- and the Rx- pins are bound to each other.
If that is not possible, we can try doing a lopback test:
For the same , we need to have the encapsulation set to hdlc, followed by the command ie :
#loopback diag
Under the Controller.
Therafter, clear the counters, and check the output of the sh controllers output.
That should be 100% clean.
So this loopback test is the finest way to know the source of the errrors/alarms.
In case if this test comes out clean that would really mean that we have no problems from the Cisco Side, and there is definitely a problem with the
Circuit line which needs to be looked at.
Hope this helps!
Rishika Goel
paolo bevilacqua Tue, 01/12/2010 - 15:19
  • Hall of Fame,
    Founding Member
Rigoel,
there is no problem, the circuit works perfectly:
   No alarms detected.
and I have indicated the meaning of the message in my other post on this thread.
Giuseppe Larosa Wed, 01/13/2010 - 03:08
  • Hall of Fame,
    Founding Member
Hello Rigoel,
Paolo is absolutely right: no alarms detected and the messsage is about last alarm received in the past
Paolo: rated as deserved
Sorry for some confusion, I've focused on finding what FEAC is and I've missed that was about the past
Hope to help
Giuseppe
paolo bevilacqua Tue, 01/12/2010 - 12:30
  • Hall of Fame,
    Founding Member
Circuit is fine and you need not to do anything.
The message reportes a previous anomaly, not the current status, that is "no alarms detected".
snickered Thu, 01/14/2010 - 11:23
One side (SITEB) of the point-to-point just showed some errors.  Here's what they look like:
sh controllers:
     0 Line Code Violations, 5 P-bit Coding Violation
     5 C-bit Coding Violation
     1 P-bit Err Secs, 0 P-bit Sev Err Secs
     0 Sev Err Framing Secs, 20 Unavailable Secs
     1 Line Errored Secs, 1 C-bit Errored Secs, 0 C-bit Sev Err Secs
sh interfaces:
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 2d03h
  Input queue: 0/75/0/1025 (size/max/drops/flushes); Total output drops: 2722
  Queueing strategy: Class-based queueing
  Output queue: 0/1000/0 (size/max total/drops)
  5 minute input rate 520000 bits/sec, 230 packets/sec
  5 minute output rate 2347000 bits/sec, 322 packets/sec
     20935554 packets input, 1426055651 bytes, 8 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
              0 parity
     86838 input errors, 85508 CRC, 0 frame, 1031 overrun, 6 ignored, 299 abort
     22527028 packets output, 292449697 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     258 unknown protocol drops
     2 carrier transitions
Now, on SITEA there are no errors at all in 'sh controllers' nor 'sh interfaces'.
sh controllers:
   Total Data (last 24 hours)
sh interfaces:
  Last clearing of "show interface" counters 2d04h
  Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 646
  5 minute input rate 2935000 bits/sec, 361 packets/sec
  5 minute output rate 564000 bits/sec, 249 packets/sec
     22886427 packets input, 468243936 bytes, 0 no buffer
              0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     21276093 packets output, 1527862884 bytes, 0 underruns
     0 unknown protocol drops
     0 carrier transitions
The carrier says it's coming from SITEA.  I don't doubt it's coming from SITEA but is it necessarily my equipment?  Should I be able to see errors on the SITEA router?  TIA.
