How do you configure snmp trap destiantions on UCM 6.1
Knightvoice_2
Is there a way to configure the SNMP trap service (if there is one) on UCM 6.1?
Thanks!
Chris
Jaime Valencia
Yes, under serviceability
Understanding Simple Network Management Protocol
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/6_1_1/admin/sasnmdes.html
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks! Is there a way to test it easily? I have gone through all of the steps but our monitoring system doesn't seem to be getting them.The guy in charge of it says his side is set up correctly.
The config is really straight-forward, not sure if there might be some service related to this.
I'll check that tomorrow
Have you checked nothing is blocking the SNMP traffic from CUCM?
java
java
