peter.grafton Tue, 02/09/2010 - 14:03
Launching CiscoWorks LMS Portal
LMS 3.2 uses port 1741 for the HTTP server and port 443 for HTTPS server (SSL).
To access the server from a client system, enter any one of these URLs in your web browser:
  • If SSL is disabled, and if you have installed LMS applications on the default port, enter:
  • <a class="jive-link-external-small" href="http://">http://</a>server_name:1741
  • If SSL is enabled, and if you have installed LMS applications on the default port, enter:
  • <a class="jive-link-external-small" href="https://">https://</a>server_name:443
    where server_name is the hostname of the server on which you have installed LMS applications.
  • If IIS is detected on your system, the port number 443 cannot be used because it causes port conflict. Instead, you can use a port number ranging from 1024 to 65535.
The CiscoWorks LMS Portal is displayed.
Related Content
