01-12-2010 05:19 PM - edited 03-06-2019 09:15 AM
hi all,
I would like to enable mls netflow in cat6500(with sup720-pfc3,msfc3)
but it is not work well.
i tested the below
conf t
mls netflow
end
cat6500#sh mls ip
Displaying Netflow entries in Active Supervisor EARL in module 5
DstIP SrcIP Prot:SrcPort:DstPort Src i/f :AdjPtr
Pkts Bytes Age LastSeen Attributes
0.0.0.0 0.0.0.0 0 : 0 : 0 -- :0x0
2438 152817 1385 19:08:52 L3 - Dynamic
as i know
"mls netflow" enable to display the flow cache in the PFC.
so the output might be displyed the below
C7600#sh mls netflow ip
Displaying Netflow entries in Supervisor Earl
10.4.9.21 10.1.9.1 132 :4011 :4011 Fa10/0/0 :0x0
98770 72848896 1788 19:10:20 L3 - Dynamic
10.8.1.11 10.1.9.1 132 :8000 :8000 Fa10/0/0 :0x0
2 160 1 19:10:20 L3 - Dynamic
in C7600, just excuting the mls netflow enables to display the flow cache in the PFC as above output.
but in cat6500, the output of "show mls netflow ip" shows just totol packets throught the device
cat6500#sh mls ip
after applying the command of "ip flow ingress" into specific interface
more detail infromation is shown
conf t
mls netflow
int gi2/5.101
ip flow ingress(==ip route-cache flow)
end
cat6500#sh mls ip
60.1.101.5 70.1.101.5 tcp :1200 :1200 Gi2/5.101 :0x0
3691 236224 176 10:14:28 L3 - Dynamic
60.1.101.3 70.1.101.3 tcp :1200 :1200 Gi2/5.101 :0x0
60.1.101.2 70.1.101.2 tcp :1200 :1200 Gi2/5.101 :0x0
why mls netflow is fully displayed after applying the command of "ip flow ingress" into specific interface(ex. int gi2/5.101)
=> attach running config, show version and show mls netflow ip
Solved! Go to Solution.
01-12-2010 06:48 PM
It depends of the version you are running. On 7600 before 12.2(33)SRB, global configuration activated netflow on all interfaces. Starting with SRB, you need to activate Netflow per interface:
From http://www.cisco.com/en/US/docs/routers/7600/ios/12.2SR/configuration/guide/nde.html
n Release 12.2SRB, you must enable NetFlow on individual interfaces in order to enable the hardware flow cache to be populated. When enabled, the cache is populated with flows only from those interfaces where NetFlow is enabled.
•In Release 12.2SRA, configuring an aggregation scheme allows the hardware flow cache to be populated. The cache is globally populated with information for all Layer 3 interfaces.
On 6500, the same changes happened starting with 12.2(33)SXH:
Cisco IOS Release 12.2(33)SXH and later releases support per-interface NDE, which enables PFC NetFlow data collection on a per-interface basis. With releases earlier than Release 12.2(33)SXH, NetFlow on the PFC could be only be enabled and disabled globally.
Laurent.
01-12-2010 06:48 PM
Laurent.
01-12-2010 07:02 PM
thanks for your answer.
it's good help. thanks again
01-12-2010 07:25 PM
do you know how i can close this thread?
this thread is still open( "This Question is Not Answered ")
i hope to close this question.
