UPS notifications
Jan 12th, 2010
I checked through the docs and could not find any mention of the possibility of integrating a UPS monitoring daemon in AsyncOS.   The rest of my systems are running apcupsd in a master/slave configuration.
steven_geerts Sun, 01/24/2010 - 15:01
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Hello Matthew,
You are right! That is simply not one of the ASyncOS functionalities. I suppose that's because it's hard to make sure all UPS vendors are supported and.... maybe more important.... since not many enterprises are using this functionality. (As far as I know, correct me if I’m wrong.)
Maybe you can write a script to bring your Ironport(s) down, that is executed form one of you UPS controlled hosts, just before that host is shut's down by an UPS notification.
I must make the remark that shutting down an Ironport before a power outage makes sense. Ironport is also using some DB functionality internally and those DB('s) can be damaged by a hard power off.
Hope this helps.
