LMS 3.2 product suite
Dear all gurus,
I have a customer who is looking to use CiscoWorks LMS solution to manage their existing infrastructure.  Since this is the first time we sell Cisco LMS 3.2, would appreciated your kind assistance.
My customer currently has the following network equip:
4 x 6509s with FSM (WS-C6509-E-FWM-K9)
1 x CWWLSE-1133-K9
100 x 3560G/3750 PoE Switches
80 x Cisco 1242AG/1121G Wireless Access Point
2 x Cisco PIX515E
1 x ASA5510
1,200 x 7961/7970G Cisco IP Phones
4 x Cisco 3845 routers
3 x Cisco 4.1 CallManagers
1 x Unity 4.0
2 x Cisco Call Center Express 3.x
20 x Cisco Analogue Gateway VG224/VG248
They would like the LMS to manage all of the network infrastrcuture above together with all the IPT equip including all the Cisco IP Phones.
Would it be enough to order:
1 x CWLMS-3.2-300-K9
1 x 1 CPU with 2 GB RAM and 4 GB swap space (Using Windows Server 2003)
OR
1 x CWLMS-3.2-1.5K-K9
1 x 2 CPUs at 3.66 GHz with 4 GB RAM and 8 GB swap space (Using Windows Server 2003)
Is there anything else I need to order on top of the above Cisco part codes??
I have spent a lot of time on this already but didn't go very far  =)
Cheers,
Hunt
Marvin Rhoads Wed, 01/13/2010 - 05:26
The product will run much better if you use the 64-bit version of the OS and add more RAM. Windows Server 2008 x64 (do NOT use R2) and 8 GB of RAM will serve you better.You can't have too much RAM (if you use a 64-bit OS) and it is relatively inexpensive.
If you want to use the HUM component, that is separately licensed.
