Autonomous APs to LWAPP
Answered Question
Jan 13th, 2010
I have a project to upgrade the current Autonomous APs 1242 running on a customer site and they want them to be converted to LWAPP and moved over to controller.Is there a way to convert them? Note the APs are about 12-15ft high in the ceiling.
Correct Answer by Leo Laohoo about 7 years 1 month ago
Unless you know some IOS upgrade commands, I'd recommend you stick with the Upgrade Tool.  The "archive" command is used to upgrade the firmware from your TFTP server to the appliance where you are running the command from.
Overall Rating: 5 (1 ratings)
jcomment Wed, 01/13/2010 - 07:08
Do I need to remove the existing config off the APs and can I keep the current IP Address?
Leo Laohoo Wed, 01/13/2010 - 13:19
Depending on the firmware your WLC is running it is possible.  If you look at the Conversion Tool there is a tick box to keep the static IP address.
Correct Answer
Leo Laohoo Sun, 01/17/2010 - 13:20
Related Content
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
