Catalyst 6500-E - WS-SVC-CMM
hotshot979
     Hi I have a problem installing WS-SVC-CMM module in 6509-E. The problem is that the module goes down and stays in that state.
Goce
6 Replies 6
Jon Marshall
What IOS are you running on the switch ?
Jon
Hi Jon,
This is the IOS on the 6500 : s72033-advipservicesk9-mz.122-33.SXI2a.bin
Goce
hotshot979 wrote:
Hi Jon,
Goce
Sorry, should have asked, what supervisor are you running ?
Also, can you post output of
sh module
sh power or sh env power
Jon
Amit Singh
Hi  Goce,
Is this a new installation or an older one?
Are you using this module with Sup720-10G in VSS configuration. If yes, then it is not  supported in VSS configuration.
If it is not the VSS configuration or you are using SUP720, you needed miniumum 12.2(13)ZP1 or later on the CMM module as it runs its own software.
As requested by Jon , please paste the output of " Show module ".
regards,
-amit singh
Hi guys,
The IOS on the CMM module is wscmm-i6k9s-mz.124-3g.bin and this is the output of the show commands on 6509-E. Also you can notice, right now the CMM module is not in this chasis, it's still in the old 6509 (not 6509-E) chasis. It is not working in VSS mode also
------------------ show module ------------------
Mod Ports Card Type                              Model              Serial No.
  1   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1337YPS4
  3   24  CEF720 24 port 1000mb SFP              WS-X6724-SFP       SAL1338YSXY
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1337YJUA
  6    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL1337YMS9
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0026.cb77.91c8 to 0026.cb77.91df   4.1   12.2(18r)S1  12.2(33)SXI2 Ok
  3  0026.cbb1.1fe4 to 0026.cbb1.1ffb   4.1   12.2(18r)S1  12.2(33)SXI2 Ok
  5  001f.9e2a.0ca0 to 001f.9e2a.0ca7   3.1   8.5(3)       12.2(33)SXI2 Ok
  6  0021.a094.8a18 to 0021.a094.8a1f   3.1   8.5(3)       12.2(33)SXI2 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card WS-F6700-DFC3C     SAL1338YT6X  1.4    Ok
  3  Distributed Forwarding Card WS-F6700-DFC3C     SAL1338YT81  1.4    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1337YKTJ  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1334X11G  2.0    Ok
  6  Policy Feature Card 3       VS-F6K-PFC3C       SAL1337YGDN  1.1    Ok
  6  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1335XBBK  2.0    Ok
Mod  Online Diag Status
  1  Pass
  3  Pass
  5  Pass
  6  Pass
------------------ show power ------------------
system power redundancy mode = redundant
system power total =     3795.12 Watts (90.36 Amps @ 42V)
system power used =      1152.48 Watts (27.44 Amps @ 42V)
system power available = 2642.64 Watts (62.92 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
2    WS-CAC-4000W-INT   3795.12 90.36  OK     OK     on
                        Pwr-Allocated  Oper
Fan  Type               Watts   A @42V State
1    WS-C6509-E-FAN      150.36  3.58  OK
                        Pwr-Requested  Pwr-Allocated  Admin Oper
Slot Card-Type          Watts   A @42V Watts   A @42V State State
1    WS-X6724-SFP        162.96  3.88   162.96  3.88  on    on
3    WS-X6724-SFP        162.96  3.88   162.96  3.88  on    on
5    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
6    VS-S720-10G         338.10  8.05   338.10  8.05  on    on
system auxiliary power mode = off
system auxiliary power redundancy operationally = non-redundant
system primary connector power limit =   10920.00 Watts (260.00 Amps @ 42V)
system auxiliary connector power limit = 10500.00 Watts (250.00 Amps @ 42V)
system primary power used =              1152.48 Watts (27.44 Amps @ 42V)
system auxiliary power used =            0 Watt
I tried looking around and found out that you might be hitting a software bug on the CMM. Try upgrading the CMM software to
12.4.10T in the T train or to atleast 124-21 or the latest one in the mainline train.
Link to download the software for CMM :
http://www.cisco.com/public/sw-center/index.shtml
HTH,
-amit singh
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
