[SOLVE] - CAD and Windows Seven
Jan 11th, 2010
Is the CAD 7,5 support on windows seven ? (the system requierment does not mention this)
Thinks, and happy new year for all.
Overall Rating: 5 (1 ratings)
Soman Nair Mon, 01/11/2010 - 10:05
Hi Philippe,
Have a fantastic year ahead.
As per Cisco CCBU: Windows 7 will be supported on CTIOS 7.5(8) and 8.0. Both will release in Feb/March 2010. - there are currently no plans for support of the code base prior to 7.5.(x).
Soman Nair.
(Pls rate if this was helpful.)
Soman Nair Wed, 01/13/2010 - 04:27
Hi Philippe,
That's absolutely fine.. No worries..  Hope this query is answered, and you can mark it as "Solved" . Have a nice time.
Soman Nair.
phamvinhdat Fri, 01/29/2010 - 11:06
Here is the work around for installing CAD on Windows 7
- Copy the installation to local machine
- Right click on installation file click on Properties
- Select the compatibility tab
- check mark Run this program in compatability mode for "Previous version of Windows"
This will let you install the CAD
Dat Pham
