LMS 3.1 ->RME4.2
Answered Question
Jan 13th, 2010
Running LMS 3.1 RME 4.2.0   when trying to do a software update or upgrade analysis under RME Software management I am not able to select any device in the Device selection window. I can put a tick in All devices checkbox but it doesn't actually select any devices. I can drill down to an individual device but cannot select it. no tick appears in the checkbox. Please assist
Correct Answer by aryarahul about 3 years 2 months ago
I am having the same issue , rebooting doesnt help
Any other solutiuon to this ?
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 01/13/2010 - 10:24
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This sounds like an RME package problem.  Post the swim_debug.log in addition to the NMSROOT/MDC/tomcat/logs/stdout.log and stderr.log.
Joe Clarke Fri, 01/15/2010 - 14:10
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I'm not seeing any relevant errors to what I think you are describing.  Post a screenshot illustrating the problem.
Joe Clarke Mon, 01/18/2010 - 11:49
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This is config archive, not SWIM.  Post the dcmaservice.log and dcmaclient.log.
YANNICK GUENVER Tue, 01/19/2010 - 00:56
     OK. We have the same pb with config archive. Please find in attach the requested files.
     Best regards,
Joe Clarke Tue, 01/19/2010 - 12:36
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Post the list of contents under NMSROOT/MDC/tomcat/webapps/rme/lib/pkgs.
YANNICK GUENVER Wed, 01/20/2010 - 00:18
  Please find in attach the contents under NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs.
  The path  NMSROOT/MDC/tomcat/webapps/rme/lib/pkgs does not exist
Best Regards
Yannick
Joe Clarke Sat, 01/23/2010 - 09:35
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
I was hoping for the output of DIR for this directory from a DOS prompt.  I would also like to see a DCR export for one of the devices which is not selectable.
YANNICK GUENVER Wed, 01/27/2010 - 00:18
Since we have reboot the server this We we can now select device in RME .
Many thanks for your help.
Yannick
Correct Answer
aryarahul Wed, 03/26/2014 - 23:45
Vinod Arya Thu, 03/27/2014 - 04:21
  • Cisco Employee,
Rahul,
I think you have issues with your LMS 3.1 server which has been advsied in some other threads to upgrade to atleast LMS 3.2.1 which is free upgrade for you.
Using a End of support product will have consequenses of lack of support mostly. Let us know the challenges you have in upgrade.
People here in CSC can help and suggest solutions.
-Thanks
Vinod
YANNICK GUENVER Thu, 03/27/2014 - 01:43
Hello aryara
Our LMS 3.1 is unplugged now ! Have you try to update RME 4.2 to the last release available ?
Yannick
