HP ProCurve VLAN trunking to Cisco
Jan 13th, 2010
Im missing something obvious here......
I have a HP Procurve 5406 connected to a Cisco 3560 on a temporary cat5e connection and I have Mitel IP phones needing to go on the Cisco switch.
Ive configured the HP Procurve port to TAGGING both VLAN 10 (data) and VLAN 20 (Voice). NO is selected for default VLAN 1.
The Cisco is configured on the port with switchport encap dot1q and switchport mode trunk.
Ive configured an IP for interface VLAN 10 and i cannot ping it from across the network. The interfaces are up and happy. I have tried changing the VTP status from transparent to server (VTP pruning is off) ive tried setting allowed vlans 10,20. Still not a think.
Have i missed something?
The worse thing is that i have a working Cisco switch with the HP procurve that i checked the config on and its the same! The only difference is that the media type is SX over SFP in that case.
p.s not that im at this stage yet but i initially configure the FastE ports as trunks with native vlans because i was using non-cisco phones. On a spare port i convigured the voice vlan 20 and i say on the mitel phone that it was looking on vlan20! I didnt expect that, i thought the Voice VLAN ID was carried on CDP enabled devices only.
/Jon
s.marino Wed, 01/13/2010 - 07:54
Jon,
The CAT5e cable, is it a crossover between the switches?  Does it show the link up on both sides.
gbljoba Wed, 01/13/2010 - 08:04
Yes the link is UP on both sides. Both sides are supporting MDIX.
/Jon
solpandor Wed, 01/13/2010 - 08:57
John
I guess you are trying to ping the SVI of Vlan 10?
I know im stating the obvious but have you assigned a port to vlan 10?
Giuseppe Larosa Wed, 01/13/2010 - 09:09
Hello Jon,
as suggested by Solpandor you should verify
if you like use and post:
sh vlan id 10
sh vlan id 20
sh spanning-tree vlan 10
sh spanning-tree vlan 20
sh int vlan 10
there is a feature that on C6500 is called autostate that links the state of SVI vlan10 (L3 object) to the existence of a L2 port (access or trunk) in STP forwarding for vlan10. The feature is present in all multilayer switch.
Hope to help
Giuseppe
gbljoba Fri, 01/15/2010 - 03:26
ok here goes;
Switch#sh vlan id 10
VLAN Name                             Status    Ports
10   data_skem                        active    Fa0/2, Gi0/1
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
10   enet  100010     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
Switch#sh vlan id 20
20   VOICE_MITEL                      active    Fa0/2, Gi0/1
20   enet  100020     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Switch#sh span vlan 10
MST0
  Spanning tree enabled protocol mstp
  Root ID    Priority    32768
             Address     0022.bebb.2e00
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32768  (priority 32768 sys-id-ext 0)
Interface        Role Sts Cost      Prio.Nbr Type
Gi0/1            Desg FWD 20000     128.1    P2p
Switch#sh span vlan 20
MST0
Switch#sh int vlan 10
Vlan10 is up, line protocol is up
  Hardware is EtherSVI, address is 0022.bebb.2e41 (bia 0022.bebb.2e41)
  Internet address is 10.48.90.29/23
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Last input 1d21h, output 00:04:57, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     265 packets input, 106000 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     52 packets output, 3328 bytes, 0 underruns
     0 output errors, 1 interface resets
All ports are in FWDing stats on both sides, to be safe, i changed the priority.
I really appreciate this
/Jon
Peter Paluch Fri, 01/15/2010 - 15:01
Hello Jon,
Can you please also post the configuration of the Gi0/1 interface on your 3560 and the configuration of VLANs 10 and 20 from your HP ProCurve switch? Also, I would be interested in seeing the show interfaces trunk plus show mac address-table int gi0/1 on the 3560 and show mac-address N on the HP (where N is the port going towards the 3560) to see if the  the ports are actually learning MAC addresses at all.
Best regards,
Peter
billy.williams@... Wed, 01/09/2013 - 07:08
Try using the switchport trunk non negotiate on the Cisco switch.
