SPA8000 - whats the maximum distance per analog phone?
Jan 13th, 2010
Dear Sir/madam,
I'm looking at implementing a SIP proxy server with about 20 units of SPA8000 (full load with 8 analog phones each).
However, i do have some concern on the following justifcation points.
1. Whats the maximum distance a single SPA8000 unit can drive per analog phone? (assuming all 8 ports are being connected to an analog phone each)
2. If i've a delicated lan for the implementation, is QoS settings necessary? (any documentation for the best practices for the SPA8000 ?
Alberto Montilla Wed, 01/13/2010 - 10:01
Hi Raymond;
With regards of your questions:
(1) Distance: If you are connecting only one phone with normal REN (<1), max, distance is approx. 975 m. Check for further information.
(2) LAN requirements: You should enable quality of service to ensure that in case someone places a PC in the same network, it does not hurt voice quality. There are multiples possibilities depending on complexity: separate VLANs or just IP (DSCP) QoS trust. For SPA8000 and if you have a dedicated LAN for this implementation, IP (DSCP) QoS trust must be enough. The SPA8000 marks the packet automatically, so only thing you need to configure is the switch.
