Tommer Catlin Wed, 01/13/2010 - 08:37
  • Green, 3000 points or more
Looks like an old version of CUCM.  You simple start and stop the DRS services to stop the backup.
Try backing up to a different SFTP source.  I have had issues, even with new 7.1 servers, the DRS did not like the backup server for some reason or the software.
Possibly delete the backup source (machine).  Restart the service, then add the source back in and run a test to see if it works then.
Rob Huffman Wed, 01/13/2010 - 10:04
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Kadambari,
Just to add a link to the great tips from Tommer (+5 points TCAT!)
CSCsr87199 Bug Details Bug #18 of 39 | < Previous | Next >
DRS backup never releases lock - stops performing backups
Symptom:
- DRS Backups stop executing automatically.
- When you attempt a manual backup, you get an error saying:
"Backup operation currently in progress.... please wait and try after sometime"
- When trying to install a new version or a COP file, you get the following error:
"The system is currently locked by another process. Please try again later"
Conditions:
Occurs if DRF is scheduled to backup the CUCM server automatically.
Workaround:
Restart the DRF Master Agent on the publisher to be able to install files again
Status
Fixed
Severity
3 - moderate
Last Modified
In Last month
Product
Cisco Unified Communications Manager (CallManager)
Technology
1st Found-In
7.0(1.10000.11)
Fixed-In
7.1(1.39000.81)
7.0(1.21022.1)
7.0(2.11006.1)
7.1(2.10000.16)
Hope this helps!
Rob
