Voice & Data VLAN Configuration
Jan 13th, 2010
Greetings, We had a vendor install all our switches and I've found that the switch configurations for voice & data are a little different. They are configured either as (where vlan 10 = data, vlan 172 =voice):
interface FastEthernet0/2
switchport access vlan 10
switchport mode access
switchport voice vlan 172
mls qos trust dscp
spanning-tree portfast
OR....
interface GigabitEthernet0/6
switchport trunk native vlan 10
switchport mode trunk
mls qos trust dscp
I've also see the voice configured as:
switchport access vlan 172
And some ports (that are not connected to 'static' devices such as a router) configured with switchport mode trunk, and also had voice running on it.
I'm trying to get all configurations consistent across the board. Can anyone tell me if there is a best way to approach this? Is one configuration going to give better performance than another?
Chris
P.S. The switches are Catalyst 3650, running 12.2 (35)SE5 IOS.
Reza Sharifi Wed, 01/13/2010 - 08:27
  • Cisco Designated VIP,
    2017 LAN
Hi Chris,
For your first solution, Cisco calls this a Multi-Vlan access port, and NOT a trunk port. But we all know if you have more then one vlan on the port then it is trunk.  I would go with your second option:
mls qos trust dscp
https://supportforums.cisco.com/thread/1003209?tstart=30
Reza
