Help with dial-peer setup
Answered Question
dial-peer voice 10 voip
description **International Outgoing Call to SIP Trunk**
translation-profile outgoing PSTN_Outgoing
destination-pattern .T
voice-class codec 711
session protocol sipv2
session target ipv4:66.60.xx.xx
dtmf-relay rtp-nte
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
no vad
dial-peer voice 1 pots
destination-pattern 214638....
direct-inward-dial
port 1/0:0
dial-peer voice 2 pots
destination-pattern 214630....
direct-inward-dial
port 1/0:0
Is the existing config.  Well actually there are a couple more dial peers but with specific #'s on them, dial-peer voice 3 and 4 pots
The isue is they want to call a 214638xxxx Number that isn't on their PBX, so when they try to call it, it makes the dial-peer voice 1 pots
Where in the config would I put that specific number to have it work?  I was thinking
dial-peer voice 11 voip
destination-pattern 214638XXXX
Is that correct?  Would I need to delete all dial-peers and re-add them with 11 in the correct order?
Tim
Message was edited by: TIMOTHY GRIMES
Correct Answer by Chris Deren about 7 years 2 months ago
Correct, simply add a dial peer with closer match and it will be used.
HTH,
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Wed, 01/13/2010 - 07:52
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
HTH,
Chris
