routing question...
Jan 13th, 2010
Alright, this is going to sound really stupid but I've just overconfused myself.
Here is a little background info.
I have a cisco 3560G
We currently have a 10.1.2.0 255.255.255.0 subnet
All workstations are on VLAN10 as well as anything on the 10.1.2.0 network.
If i want to start IPing some machines as 10.1.3.0 what do I need to do?  We have other machines on the same network as 10.1.5.0 and so on but those sites are connected with routers so it knows where to put the information...
can i add a secondary IP to vlan 10 so I can give a machine on 10.1.3.0 a correct gateway?  (assuming i do the configuration on the 3560G) or do I just add a secondary IP to the 3560 itself and use that as the gateway?
I know it's a bad idea to do this but i'm just curious as to how to make this work...i believe my issue is i don't have a gateway for a machine on 10.1.3.0 to talk to so the switch can tell it how to talk to the other networks and i'm not sure how to assign one to that switch.
Jon Marshall Wed, 01/13/2010 - 11:00
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
John
The way to do this on a L3 switch is not by using secondary IPs but to create a separate vlan and L3 vlan interface ie.
on the 3560 switch
ip routing (in case it is not enabled)
int vlan 11
ip address 10.1.3.1 255.255.255.0
then one each port that has a device in vlan 11
int fa0/1
switchport mode access
switchport access vlan 11
then set the default-gateway of each device in vlan 11 ot 10.1.3.1
Jon
johnwhites Wed, 01/13/2010 - 11:03
ahh, okay, so there would be no way for me to have the two subnets working properly on the same vlan with only the L3 switch?
Jon Marshall Wed, 01/13/2010 - 11:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
Apologies if i misled you. Yes you can apply a secondary IP address under the vlan interface ie.
int vlan 10
ip address x.x.x.x x.x.x.x
ip address y.y.y.y y.y.y.y secondary
I was just saying that generally speaking on L3 switches that's not the way we tend to configure it.
Jon
johnwhites Wed, 01/13/2010 - 11:22
ahh see that's what i thought but when i try to input that command i get an invalid input at the part where you type secondary so that's where i've been stuck...can you only do that on a router?
Jon Marshall Wed, 01/13/2010 - 11:24
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
Some switches take it. What model switch and which IOS version are you running ?
Jon
johnwhites Wed, 01/13/2010 - 11:29
it's 48pt WS-C3560G running 12.2(25)SEB4-IP-BASE looks like.
Jon Marshall Wed, 01/13/2010 - 12:01
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Well according to the command reference you should be able to add the "secondary" keyword.
So you are doing this
3560(config)# vlan 10
3560(config-if)# ip address 192.168.5.10 255.255.255.0 secondary
and it is erroring on the "secondary" keyword ?
Jon
johnwhites Wed, 01/13/2010 - 12:17
well i actually have to do:
int vlan 10
and then
ip address 10.1.2.3 255.255.255.0
if i add secondary at the end
ip address 10.1.2.3 255.255.255.0 secondary
it errors at secondary.    ^
milan.kulik Thu, 01/14/2010 - 07:04
  • Red, 2250 points or more
according to the Command Reference Guide
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_25_sed/command/reference/cli1.html#wp1861936
the secondary IP address should be available for your IOS.
When you issue
ip address 10.1.2.3 255.255.255.0 ?
does your CLI offer you the "secondary" option?
As SEB means "Special and Early Deployments", I'd try to upgrade to latest IOS, though.
BR,
Milan
Richard Burts Mon, 01/18/2010 - 10:08
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
John
Does Vlan 10 already exist? What happens if you assign a switch port to Vlan 10? Is anything else configured on interface vlan 10 when you attempt the secondary address configuration? If so, what is already configured?
Rick
